tuning questions
dsm199994
57
5
Apr 9, 2013
n.tonawanda, New York
Ok, so I have a ton of questions right now I have a 98 gst the previous owner had put a fmic evo3 16g turbo and 3 in downpipe/exhaust I drove the car last summer twice second time the clutch exploded and trashed the granny so I'm doing a new tranny clutch and timing belt. I believe ever thing else is stock, my questions are what else do I need to run 19psi on this car and I know absolutely nothing about what to tune with or even how to tune. If any one can tell me what a good tuning method for my 19psi goal and what I have to do to install it and other mods I need as well... Its my first time working with a 4g63 as I started with a 420a :D
If all you want is 19psi an SAFC, 190 fuel pump and say 650cc injectors will do it.
BUT, trust me you won't want to stop at 19psi. So I highly suggest investing in DSMlink. Along with a 255 fuel pump or something bigger and a AFPR. And with DSMLink you can run any size injector you want.
Along with what I mentioned, around that boost level and higher, getting ARP headstuds is also recommended.
Ok is safc easy to tune with is there any sites or links that explain how to use/install it? is dsmlink better for tuning? I will need a wideband to right? I'm just scared to mess anything up on this cal LOL. Car is not a 420a I own 3 2g eclipse two are 420a and the third is a gst
Thanks for the replies in gonna be putting this all together in the next 3 weeks or so. And if any one has any Leads on a 7bolt front wheel drive 5speed for sale please pm me.
Well that makes more sense your profile was a non turbo, but onto tuning link is good but, there are other choices out there, ecu flash, ecmlink, a safc I would look into reading upon those things lots of information on those on this site. Welcome to the site.
