Tuning Question with MAF-T 2g
Clipz0801
32
Aug 9, 2006
Fair Lawn, New Jersey
Just wondering what settings, and stuff i have to have, and set up with the MAF-T. i've read the tuning guide and looked at feedback, but its still jibberish a bit to me. The car runs fine until about 3000rpms until were the car stutters while accelerating in all gears. My mods are as follows;
Dejon FMIC
Dejon Blow-thru set up
GM MAF 3"
GM MAF-T
16g Big EVO III
GT Headers
HKS SSQV
HKS MBC
Dejon Intake
3 x 6 K & N Filter
i have stock exhaust and downpipe, which i will be replacing very soon.
Anyone have any .02 on whats wrong, or maybe what they set the car to under the MAF-T. So atleast i can run without the stuttering untill the car is properly tuned. Btw im running at 16psi for now.
That is too much boost for the stock fuel system I'd say run 14psi max.
If you are on stock injectors you'll want to set it for that. The tuning guide can be found here. http://www.fullthrottletech.com/showthread.php?t=105
Do you have a datalogger or Wideband O2? You need something to tune with, the logger being the minimum. It should run on base settings, but will need fine tuning with a logger to get any kind of decent tune out of it and to be sure it's safe.
forgot to mention i have 550cc injectors with a walbro 255lb pump. I just ordered the APexi SAFC witht the greddy logger, is there anything i should be heads up.
