Tuning problems wbo2 vs. O2
eclipsegst1990
118
Mar 15, 2005
GLOUCESTER CITY, New Jersey
Hello everyone. I have problems posting in the tuning section lately, so I will give this a try.
Here's the situation. I've been tuning my GVR4 for a while now and I haven't been getting very far. The car pulls with the EVOIII, but not like it should.
I've done many 3rd gear pulls and can't understand why I continue to get knock with conflicting WBO2 and O2 readings. I can basically tune the knock out by raising the fuel, but the fuel is already rich according the my WBO2 readings. My IDC is also very high right now. I've logged the WBO2 readings, but they're in "temp" and I don't recall the formula to convert them in Excel. However, on my logger, the WBO2 hangs in the 9.0 range in the upper RPM area which is way rich, but the stock O2 "relatively new" relates that I'm running somewhat lean. When I bump up the fuel, the knock seems to leave, but my performance seems to suffer. If I try to turn down the fuel as per the WBO2, I get hella knock. I have the MAFT V2 and have tried several different settings to try to tune for 11.0 or 11.5, but form some reson I can't get the WBO2 fuel to drop below 9.?? unless I'm in the lower RPM area. Right now I'm (AUX 0, BASE 2, IDLE 5, MID 2, HIGH 3.) I've tried (AUX 1, BASE 7, IDLE 1, MID 1, HIGH 1 which produces the same results with the WBO2 reading 9. on the upper range, but with a significantly lower injector duty cycle which is sweet, but my power is even worse. I have several logs, but I posted the first one for now. My fuel base is set at the AFPR for 37psi (vac line off and sealed method). My plugs were recently changed from BPR6ES to BR7ES with new wires. EGT's seem to be reading ok <1550 (I wish I could log them though).
ERPM EGRT O2-R KNCK INJP --- TIMA
906.25 220.00 0.68 0.00 2.05 1.00 11.00
906.25 220.00 0.43 0.00 2.05 1.00 10.00
906.25 220.00 0.10 0.00 2.05 1.00 12.00
906.25 220.00 0.04 0.00 2.05 1.00 11.00
906.25 221.00 0.04 0.00 2.05 1.00 12.00
906.25 220.00 0.06 0.00 2.05 1.00 11.00
906.25 220.00 0.08 0.00 2.05 1.00 11.00
906.25 219.00 0.06 0.00 2.05 1.00 11.00
906.25 219.00 0.10 0.00 2.05 1.00 9.00
906.25 220.00 0.25 0.00 2.05 1.00 11.00
937.50 219.00 0.18 0.00 2.05 2.00 10.00
906.25 220.00 0.66 0.00 2.05 1.00 11.00
906.25 219.00 0.70 0.00 2.05 1.00 11.00
906.25 220.00 0.72 0.00 2.05 1.00 11.00
906.25 220.00 0.62 0.00 2.05 1.00 11.00
906.25 220.00 0.47 0.00 2.05 1.00 11.00
906.25 219.00 0.04 0.00 2.05 1.00 11.00
906.25 220.00 0.02 0.00 2.05 1.00 11.00
906.25 220.00 0.04 0.00 2.05 1.00 12.00
875.00 219.00 0.04 0.00 2.05 1.00 11.00
937.50 219.00 0.04 0.00 2.05 2.00 10.00
937.50 219.00 0.02 0.00 4.10 4.00 10.00
1593.75 219.00 0.60 0.00 2.82 4.00 15.00
2156.25 219.00 0.02 0.00 3.84 8.00 30.00
2593.75 218.00 0.02 0.00 3.84 10.00 29.00
2500.00 219.00 0.02 0.00 4.10 10.00 29.00
2406.25 219.00 0.02 0.00 4.61 11.00 29.00
2156.25 219.00 0.57 0.00 4.86 11.00 27.00
2031.25 218.00 0.49 0.00 5.12 11.00 25.00
1937.50 219.00 0.08 0.00 5.38 11.00 22.00
1906.25 206.00 0.66 0.00 5.38 10.00 20.00
2218.75 177.00 0.33 0.00 5.38 12.00 21.00
2500.00 209.00 0.14 0.00 5.38 14.00 24.00
2781.25 185.00 0.64 0.00 5.38 15.00 26.00
3156.25 168.00 0.53 0.00 5.89 19.00 27.00
3531.25 129.00 0.70 0.00 6.14 23.00 26.00
3875.00 118.00 0.78 0.00 4.10 16.00 26.00
3656.25 56.00 0.88 0.00 1.28 5.00 33.00
3312.50 55.00 0.72 0.00 1.28 4.00 40.00
3031.25 219.00 0.80 0.00 2.82 9.00 40.00
2375.00 218.00 0.02 0.00 1.02 2.00 34.00
2468.75 208.00 0.10 0.00 5.12 13.00 27.00
2687.50 218.00 0.02 0.00 5.38 15.00 26.00
2843.75 217.00 0.02 0.00 5.89 17.00 26.00
2937.50 213.00 0.02 0.00 6.14 19.00 24.00
3093.75 181.00 0.08 0.00 6.91 22.00 24.00
3250.00 148.00 0.66 1.00 7.68 26.00 22.00
3468.75 116.00 0.74 1.00 8.45 31.00 23.00
3625.00 97.00 0.76 0.00 9.73 37.00 22.00
3843.75 88.00 0.78 0.00 7.17 29.00 19.00
3500.00 36.00 0.76 0.00 1.79 6.00 27.00
3125.00 144.00 0.21 0.00 1.02 3.00 40.00
2937.50 217.00 0.10 0.00 5.63 17.00 39.00
2593.75 217.00 0.02 0.00 5.89 16.00 25.00
2687.50 218.00 0.02 0.00 6.14 17.00 23.00
2750.00 202.00 0.02 1.00 6.40 18.00 23.00
2812.50 183.00 0.64 1.00 6.91 20.00 21.00
2875.00 160.00 0.72 0.00 7.17 22.00 21.00
2968.75 142.00 0.74 0.00 8.45 26.00 20.00
3062.50 110.00 0.80 0.00 8.70 28.00 18.00
3125.00 93.00 0.78 0.00 9.73 32.00 18.00
3250.00 88.00 0.78 0.00 10.75 37.00 17.00
3343.75 80.00 0.78 0.00 11.52 41.00 15.00
3468.75 64.00 0.78 0.00 12.80 47.00 15.00
3593.75 56.00 0.78 0.00 14.08 54.00 15.00
3718.75 54.00 0.78 7.00 15.62 62.00 16.00
3875.00 48.00 0.78 7.00 16.13 66.00 14.00
4000.00 30.00 0.78 7.00 16.64 71.00 15.00
4125.00 30.00 0.78 6.00 16.64 73.00 16.00
4250.00 30.00 0.78 6.00 17.41 79.00 16.00
4406.25 30.00 0.78 5.00 17.15 80.00 16.00
4500.00 29.00 0.78 5.00 17.92 86.00 16.00
4593.75 30.00 0.76 5.00 17.66 86.00 16.00
4750.00 29.00 0.78 5.00 17.92 90.00 16.00
4843.75 28.00 0.76 4.00 18.18 94.00 17.00
4968.75 28.00 0.76 4.00 18.43 97.00 17.00
5093.75 28.00 0.74 3.00 19.20 104.00 17.00
5187.50 27.00 0.74 3.00 18.69 103.00 19.00
5312.50 28.00 0.76 3.00 18.43 104.00 20.00
5437.50 28.00 0.74 3.00 18.43 107.00 20.00
5531.25 28.00 0.74 2.00 18.43 108.00 20.00
5656.25 28.00 0.74 4.00 18.43 111.00 21.00
5843.75 28.00 0.74 4.00 18.43 115.00 21.00
5781.25 26.00 0.74 3.00 18.18 112.00 22.00
5968.75 28.00 0.72 3.00 18.18 115.00 23.00
6031.25 27.00 0.72 8.00 18.69 120.00 21.00
6125.00 27.00 0.76 7.00 18.43 120.00 20.00
6250.00 27.00 0.72 7.00 18.18 121.00 20.00
6312.50 26.00 0.72 7.00 18.43 124.00 19.00
6406.25 26.00 0.72 6.00 18.69 127.00 20.00
6500.00 25.00 0.72 6.00 17.66 122.00 19.00
5968.75 35.00 0.82 0.00 1.54 9.00 18.00
5187.50 78.00 0.76 0.00 7.42 41.00 45.00
4812.50 200.00 0.12 0.00 9.73 50.00 27.00
4906.25 108.00 0.80 0.00 1.28 6.00 25.00
4750.00 173.00 0.66 0.00 1.28 6.00 45.00
4781.25 219.00 0.31 0.00 1.28 6.00 45.00
4750.00 219.00 0.70 0.00 1.28 6.00 45.00
4687.50 219.00 0.76 0.00 1.28 6.00 44.00
4625.00 219.00 0.70 0.00 0.00 0.00 31.00
4500.00 219.00 0.02 0.00 0.00 0.00 31.00
4468.75 219.00 0.02 0.00 0.00 0.00 31.00
4406.25 219.00 0.02 0.00 0.00 0.00 31.00
4343.75 219.00 0.02 0.00 0.00 0.00 30.00
4281.25 220.00 0.02 0.00 0.00 0.00 30.00
4218.75 219.00 0.02 0.00 0.00 0.00 30.00
4125.00 219.00 0.02 0.00 0.00 0.00 29.00
4062.50 219.00 0.02 0.00 0.00 0.00 29.00
4000.00 219.00 0.02 0.00 0.00 0.00 28.00
3937.50 219.00 0.02 0.00 0.00 0.00 28.00
3875.00 219.00 0.02 0.00 0.00 0.00 28.00
3812.50 219.00 0.02 0.00 0.00 0.00 28.00
3750.00 220.00 0.02 0.00 0.00 0.00 28.00
3687.50 219.00 0.02 0.00 0.00 0.00 27.00
3625.00 219.00 0.02 0.00 0.00 0.00 27.00
3593.75 219.00 0.02 0.00 0.00 0.00 27.00
3531.25 219.00 0.02 0.00 0.00 0.00 27.00
3468.75 220.00 0.02 0.00 0.00 0.00 27.00
3406.25 219.00 0.02 0.00 0.00 0.00 27.00
3343.75 219.00 0.02 0.00 0.00 0.00 27.00
3312.50 219.00 0.02 0.00 0.00 0.00 27.00
3250.00 219.00 0.02 0.00 0.00 0.00 27.00
3187.50 218.00 0.02 0.00 0.00 0.00 26.00
3125.00 219.00 0.02 0.00 0.00 0.00 26.00
3062.50 219.00 0.02 0.00 0.00 0.00 26.00
3031.25 218.00 0.02 0.00 0.00 0.00 26.00
2968.75 219.00 0.02 0.00 0.00 0.00 26.00
2937.50 219.00 0.02 0.00 0.00 0.00 26.00
2875.00 219.00 0.02 0.00 0.00 0.00 26.00
2812.50 219.00 0.02 0.00 0.00 0.00 26.00
2750.00 219.00 0.02 0.00 0.00 0.00 26.00
2593.75 219.00 0.02 0.00 0.00 0.00 26.00
2312.50 219.00 0.02 0.00 0.00 0.00 25.00
2062.50 219.00 0.02 0.00 0.00 0.00 25.00
1812.50 220.00 0.02 0.00 0.00 0.00 24.00
1562.50 219.00 0.02 0.00 0.00 0.00 17.00
1343.75 220.00 0.02 0.00 0.00 0.00 11.00
1093.75 220.00 0.02 0.00 1.79 2.00 8.00
1000.00 220.00 0.02 0.00 1.79 1.00 16.00
1031.25 219.00 0.02 0.00 1.79 1.00 21.00
1031.25 220.00 0.02 0.00 1.79 1.00 20.00
1000.00 220.00 0.06 0.00 1.79 1.00 17.00
1000.00 220.00 0.06 0.00 1.79 1.00 16.00
1000.00 220.00 0.08 0.00 1.79 1.00 15.00
1000.00 219.00 0.21 0.00 1.79 1.00 15.00
1000.00 220.00 0.66 0.00 1.79 1.00 13.00
Here's nother log. Hopefully this is easier to ready. This is a completely different log using same MAFT settings. Either way I can tune the knock out, but the fuel is the problem. The duty cycles are a threat to the injectors, but I shouldn't be outflowing PTE680s (650s) with 20psi of boost on an EVOIII. Something is definitely wrong. When I change the MAFT settings using AUX1, the IDC are significanly lower, but the performance is even worse with minimal knock and same WBO2 afr. Either way, there is no popping or stuttering on any of the pulls.
Code:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
</head>
<body>
<table border="2" cellspacing="2" cellpadding="2">
  <tr>
    <td><b>ERPM</b></td>
    <td><b>TIMA</b></td>
    <td><b>EGRT</b></td>
    <td><b>O2-R</b></td>
    <td><b>KNCK</b></td>
    <td><b>INJP</b></td>
    <td><b>INDC</b></td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>12.00</td>
    <td>219.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.12</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>10.00</td>
    <td>218.00</td>
    <td>0.12</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.25</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>10.00</td>
    <td>220.00</td>
    <td>0.12</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.68</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>10.00</td>
    <td>219.00</td>
    <td>0.74</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.74</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>10.00</td>
    <td>219.00</td>
    <td>0.29</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.10</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.08</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>10.00</td>
    <td>219.00</td>
    <td>0.58</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>12.00</td>
    <td>220.00</td>
    <td>0.68</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.74</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.76</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>218.00</td>
    <td>0.76</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>12.00</td>
    <td>220.00</td>
    <td>0.68</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.55</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>12.00</td>
    <td>218.00</td>
    <td>0.08</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>12.00</td>
    <td>219.00</td>
    <td>0.08</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.66</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.70</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>13.00</td>
    <td>219.00</td>
    <td>0.08</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>12.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.04</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>11.00</td>
    <td>218.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>10.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.08</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>10.00</td>
    <td>220.00</td>
    <td>0.64</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>10.00</td>
    <td>220.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.76</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>10.00</td>
    <td>219.00</td>
    <td>0.76</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.64</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>12.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.08</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>218.00</td>
    <td>0.64</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.70</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>10.00</td>
    <td>220.00</td>
    <td>0.66</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.08</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>875.00</td>
    <td>12.00</td>
    <td>219.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>12.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>9.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>906.25</td>
    <td>10.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>968.75</td>
    <td>11.00</td>
    <td>219.00</td>
    <td>0.12</td>
    <td>0.00</td>
    <td>5.12</td>
    <td>5.00</td>
  </tr>
  <tr>
    <td>1906.25</td>
    <td>18.00</td>
    <td>219.00</td>
    <td>0.80</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>4.00</td>
  </tr>
  <tr>
    <td>2218.75</td>
    <td>35.00</td>
    <td>154.00</td>
    <td>0.84</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>4.00</td>
  </tr>
  <tr>
    <td>2125.00</td>
    <td>35.00</td>
    <td>197.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>2.82</td>
    <td>6.00</td>
  </tr>
  <tr>
    <td>2187.50</td>
    <td>31.00</td>
    <td>218.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>3.58</td>
    <td>8.00</td>
  </tr>
  <tr>
    <td>2187.50</td>
    <td>28.00</td>
    <td>217.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>3.84</td>
    <td>8.00</td>
  </tr>
  <tr>
    <td>2187.50</td>
    <td>28.00</td>
    <td>218.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>4.10</td>
    <td>9.00</td>
  </tr>
  <tr>
    <td>2156.25</td>
    <td>27.00</td>
    <td>218.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>4.35</td>
    <td>10.00</td>
  </tr>
  <tr>
    <td>2156.25</td>
    <td>27.00</td>
    <td>217.00</td>
    <td>0.23</td>
    <td>0.00</td>
    <td>4.35</td>
    <td>10.00</td>
  </tr>
  <tr>
    <td>2156.25</td>
    <td>27.00</td>
    <td>218.00</td>
    <td>0.68</td>
    <td>0.00</td>
    <td>4.10</td>
    <td>9.00</td>
  </tr>
  <tr>
    <td>2062.50</td>
    <td>28.00</td>
    <td>219.00</td>
    <td>0.78</td>
    <td>0.00</td>
    <td>3.33</td>
    <td>7.00</td>
  </tr>
  <tr>
    <td>1781.25</td>
    <td>30.00</td>
    <td>199.00</td>
    <td>0.82</td>
    <td>0.00</td>
    <td>3.07</td>
    <td>5.00</td>
  </tr>
  <tr>
    <td>1843.75</td>
    <td>29.00</td>
    <td>204.00</td>
    <td>0.84</td>
    <td>0.00</td>
    <td>2.82</td>
    <td>5.00</td>
  </tr>
  <tr>
    <td>1906.25</td>
    <td>31.00</td>
    <td>201.00</td>
    <td>0.14</td>
    <td>0.00</td>
    <td>3.84</td>
    <td>7.00</td>
  </tr>
  <tr>
    <td>2187.50</td>
    <td>26.00</td>
    <td>218.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>4.86</td>
    <td>11.00</td>
  </tr>
  <tr>
    <td>2343.75</td>
    <td>24.00</td>
    <td>217.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>5.12</td>
    <td>12.00</td>
  </tr>
  <tr>
    <td>2625.00</td>
    <td>27.00</td>
    <td>217.00</td>
    <td>0.04</td>
    <td>0.00</td>
    <td>5.63</td>
    <td>15.00</td>
  </tr>
  <tr>
    <td>2968.75</td>
    <td>27.00</td>
    <td>200.00</td>
    <td>0.70</td>
    <td>0.00</td>
    <td>5.38</td>
    <td>17.00</td>
  </tr>
  <tr>
    <td>3281.25</td>
    <td>27.00</td>
    <td>139.00</td>
    <td>0.78</td>
    <td>0.00</td>
    <td>4.35</td>
    <td>15.00</td>
  </tr>
  <tr>
    <td>3125.00</td>
    <td>31.00</td>
    <td>113.00</td>
    <td>0.88</td>
    <td>0.00</td>
    <td>1.54</td>
    <td>5.00</td>
  </tr>
  <tr>
    <td>2843.75</td>
    <td>39.00</td>
    <td>134.00</td>
    <td>0.78</td>
    <td>0.00</td>
    <td>1.28</td>
    <td>3.00</td>
  </tr>
  <tr>
    <td>2656.25</td>
    <td>39.00</td>
    <td>187.00</td>
    <td>0.84</td>
    <td>0.00</td>
    <td>2.82</td>
    <td>7.00</td>
  </tr>
  <tr>
    <td>2000.00</td>
    <td>32.00</td>
    <td>104.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>4.61</td>
    <td>9.00</td>
  </tr>
  <tr>
    <td>2093.75</td>
    <td>23.00</td>
    <td>218.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>4.86</td>
    <td>10.00</td>
  </tr>
  <tr>
    <td>2218.75</td>
    <td>23.00</td>
    <td>218.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>5.12</td>
    <td>12.00</td>
  </tr>
  <tr>
    <td>2343.75</td>
    <td>24.00</td>
    <td>218.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>5.12</td>
    <td>12.00</td>
  </tr>
  <tr>
    <td>2468.75</td>
    <td>24.00</td>
    <td>217.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>5.63</td>
    <td>14.00</td>
  </tr>
  <tr>
    <td>2593.75</td>
    <td>23.00</td>
    <td>216.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>6.40</td>
    <td>17.00</td>
  </tr>
  <tr>
    <td>2750.00</td>
    <td>21.00</td>
    <td>198.00</td>
    <td>0.68</td>
    <td>1.00</td>
    <td>6.66</td>
    <td>19.00</td>
  </tr>
  <tr>
    <td>2906.25</td>
    <td>21.00</td>
    <td>128.00</td>
    <td>0.76</td>
    <td>1.00</td>
    <td>7.42</td>
    <td>23.00</td>
  </tr>
  <tr>
    <td>3031.25</td>
    <td>21.00</td>
    <td>109.00</td>
    <td>0.80</td>
    <td>0.00</td>
    <td>7.68</td>
    <td>24.00</td>
  </tr>
  <tr>
    <td>3187.50</td>
    <td>20.00</td>
    <td>88.00</td>
    <td>0.82</td>
    <td>0.00</td>
    <td>7.17</td>
    <td>24.00</td>
  </tr>
  <tr>
    <td>3125.00</td>
    <td>26.00</td>
    <td>57.00</td>
    <td>0.88</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>5.00</td>
  </tr>
  <tr>
    <td>2812.50</td>
    <td>39.00</td>
    <td>36.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>1.28</td>
    <td>3.00</td>
  </tr>
  <tr>
    <td>2718.75</td>
    <td>38.00</td>
    <td>199.00</td>
    <td>0.78</td>
    <td>0.00</td>
    <td>3.84</td>
    <td>11.00</td>
  </tr>
  <tr>
    <td>2187.50</td>
    <td>28.00</td>
    <td>84.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>5.38</td>
    <td>12.00</td>
  </tr>
  <tr>
    <td>2281.25</td>
    <td>22.00</td>
    <td>218.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>5.38</td>
    <td>13.00</td>
  </tr>
  <tr>
    <td>2312.50</td>
    <td>22.00</td>
    <td>218.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>5.63</td>
    <td>13.00</td>
  </tr>
  <tr>
    <td>2343.75</td>
    <td>21.00</td>
    <td>218.00</td>
    <td>0.04</td>
    <td>0.00</td>
    <td>6.14</td>
    <td>15.00</td>
  </tr>
  <tr>
    <td>2406.25</td>
    <td>21.00</td>
    <td>217.00</td>
    <td>0.70</td>
    <td>1.00</td>
    <td>6.14</td>
    <td>15.00</td>
  </tr>
  <tr>
    <td>2468.75</td>
    <td>20.00</td>
    <td>195.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>6.40</td>
    <td>16.00</td>
  </tr>
  <tr>
    <td>2531.25</td>
    <td>20.00</td>
    <td>160.00</td>
    <td>0.78</td>
    <td>0.00</td>
    <td>6.66</td>
    <td>18.00</td>
  </tr>
  <tr>
    <td>2593.75</td>
    <td>19.00</td>
    <td>136.00</td>
    <td>0.82</td>
    <td>0.00</td>
    <td>6.91</td>
    <td>19.00</td>
  </tr>
  <tr>
    <td>2687.50</td>
    <td>19.00</td>
    <td>125.00</td>
    <td>0.84</td>
    <td>0.00</td>
    <td>7.42</td>
    <td>21.00</td>
  </tr>
  <tr>
    <td>2750.00</td>
    <td>18.00</td>
    <td>111.00</td>
    <td>0.84</td>
    <td>0.00</td>
    <td>7.42</td>
    <td>21.00</td>
  </tr>
  <tr>
    <td>2812.50</td>
    <td>17.00</td>
    <td>95.00</td>
    <td>0.82</td>
    <td>0.00</td>
    <td>7.94</td>
    <td>23.00</td>
  </tr>
  <tr>
    <td>2875.00</td>
    <td>17.00</td>
    <td>92.00</td>
    <td>0.82</td>
    <td>0.00</td>
    <td>8.96</td>
    <td>27.00</td>
  </tr>
  <tr>
    <td>2968.75</td>
    <td>15.00</td>
    <td>83.00</td>
    <td>0.86</td>
    <td>0.00</td>
    <td>9.47</td>
    <td>30.00</td>
  </tr>
  <tr>
    <td>3031.25</td>
    <td>15.00</td>
    <td>59.00</td>
    <td>0.84</td>
    <td>0.00</td>
    <td>10.24</td>
    <td>33.00</td>
  </tr>
  <tr>
    <td>3125.00</td>
    <td>16.00</td>
    <td>57.00</td>
    <td>0.82</td>
    <td>0.00</td>
    <td>11.01</td>
    <td>36.00</td>
  </tr>
  <tr>
    <td>3218.75</td>
    <td>15.00</td>
    <td>48.00</td>
    <td>0.82</td>
    <td>0.00</td>
    <td>12.03</td>
    <td>41.00</td>
  </tr>
  <tr>
    <td>3343.75</td>
    <td>15.00</td>
    <td>43.00</td>
    <td>0.82</td>
    <td>0.00</td>
    <td>12.54</td>
    <td>44.00</td>
  </tr>
  <tr>
    <td>3437.50</td>
    <td>15.00</td>
    <td>32.00</td>
    <td>0.82</td>
    <td>0.00</td>
    <td>13.82</td>
    <td>50.00</td>
  </tr>
  <tr>
    <td>3562.50</td>
    <td>15.00</td>
    <td>32.00</td>
    <td>0.80</td>
    <td>0.00</td>
    <td>15.10</td>
    <td>57.00</td>
  </tr>
  <tr>
    <td>3656.25</td>
    <td>16.00</td>
    <td>30.00</td>
    <td>0.80</td>
    <td>0.00</td>
    <td>16.38</td>
    <td>64.00</td>
  </tr>
  <tr>
    <td>3812.50</td>
    <td>17.00</td>
    <td>30.00</td>
    <td>0.80</td>
    <td>0.00</td>
    <td>17.66</td>
    <td>71.00</td>
  </tr>
  <tr>
    <td>3937.50</td>
    <td>17.00</td>
    <td>30.00</td>
    <td>0.80</td>
    <td>0.00</td>
    <td>17.66</td>
    <td>74.00</td>
  </tr>
  <tr>
    <td>4062.50</td>
    <td>18.00</td>
    <td>30.00</td>
    <td>0.80</td>
    <td>0.00</td>
    <td>18.18</td>
    <td>78.00</td>
  </tr>
  <tr>
    <td>4187.50</td>
    <td>18.00</td>
    <td>29.00</td>
    <td>0.84</td>
    <td>0.00</td>
    <td>19.46</td>
    <td>87.00</td>
  </tr>
  <tr>
    <td>4281.25</td>
    <td>18.00</td>
    <td>29.00</td>
    <td>0.78</td>
    <td>0.00</td>
    <td>19.20</td>
    <td>87.00</td>
  </tr>
  <tr>
    <td>4406.25</td>
    <td>18.00</td>
    <td>28.00</td>
    <td>0.78</td>
    <td>0.00</td>
    <td>19.46</td>
    <td>91.00</td>
  </tr>
  <tr>
    <td>4500.00</td>
    <td>18.00</td>
    <td>29.00</td>
    <td>0.80</td>
    <td>0.00</td>
    <td>19.97</td>
    <td>96.00</td>
  </tr>
  <tr>
    <td>4593.75</td>
    <td>18.00</td>
    <td>28.00</td>
    <td>0.76</td>
    <td>0.00</td>
    <td>20.74</td>
    <td>101.00</td>
  </tr>
  <tr>
    <td>4687.50</td>
    <td>18.00</td>
    <td>28.00</td>
    <td>0.76</td>
    <td>0.00</td>
    <td>20.99</td>
    <td>105.00</td>
  </tr>
  <tr>
    <td>4812.50</td>
    <td>19.00</td>
    <td>27.00</td>
    <td>0.76</td>
    <td>0.00</td>
    <td>20.99</td>
    <td>107.00</td>
  </tr>
  <tr>
    <td>4875.00</td>
    <td>19.00</td>
    <td>28.00</td>
    <td>0.80</td>
    <td>0.00</td>
    <td>21.25</td>
    <td>110.00</td>
  </tr>
  <tr>
    <td>4968.75</td>
    <td>19.00</td>
    <td>27.00</td>
    <td>0.76</td>
    <td>0.00</td>
    <td>21.50</td>
    <td>114.00</td>
  </tr>
  <tr>
    <td>5062.50</td>
    <td>19.00</td>
    <td>27.00</td>
    <td>0.74</td>
    <td>0.00</td>
    <td>21.50</td>
    <td>116.00</td>
  </tr>
  <tr>
    <td>5250.00</td>
    <td>20.00</td>
    <td>27.00</td>
    <td>0.74</td>
    <td>0.00</td>
    <td>20.99</td>
    <td>117.00</td>
  </tr>
  <tr>
    <td>5312.50</td>
    <td>21.00</td>
    <td>27.00</td>
    <td>0.74</td>
    <td>1.00</td>
    <td>20.74</td>
    <td>117.00</td>
  </tr>
  <tr>
    <td>5437.50</td>
    <td>21.00</td>
    <td>26.00</td>
    <td>0.74</td>
    <td>0.00</td>
    <td>21.50</td>
    <td>124.00</td>
  </tr>
  <tr>
    <td>5500.00</td>
    <td>21.00</td>
    <td>25.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>21.50</td>
    <td>126.00</td>
  </tr>
  <tr>
    <td>5625.00</td>
    <td>22.00</td>
    <td>26.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>20.99</td>
    <td>126.00</td>
  </tr>
  <tr>
    <td>5656.25</td>
    <td>23.00</td>
    <td>26.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>20.99</td>
    <td>126.00</td>
  </tr>
  <tr>
    <td>5781.25</td>
    <td>23.00</td>
    <td>26.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>20.99</td>
    <td>129.00</td>
  </tr>
  <tr>
    <td>5875.00</td>
    <td>23.00</td>
    <td>25.00</td>
    <td>0.74</td>
    <td>0.00</td>
    <td>20.48</td>
    <td>128.00</td>
  </tr>
  <tr>
    <td>5968.75</td>
    <td>23.00</td>
    <td>26.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>20.74</td>
    <td>132.00</td>
  </tr>
  <tr>
    <td>6031.25</td>
    <td>24.00</td>
    <td>25.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>19.97</td>
    <td>128.00</td>
  </tr>
  <tr>
    <td>6156.25</td>
    <td>23.00</td>
    <td>26.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>20.99</td>
    <td>138.00</td>
  </tr>
  <tr>
    <td>6187.50</td>
    <td>23.00</td>
    <td>26.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>20.74</td>
    <td>137.00</td>
  </tr>
  <tr>
    <td>6281.25</td>
    <td>22.00</td>
    <td>26.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>20.74</td>
    <td>139.00</td>
  </tr>
  <tr>
    <td>6406.25</td>
    <td>21.00</td>
    <td>25.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>21.25</td>
    <td>145.00</td>
  </tr>
  <tr>
    <td>6500.00</td>
    <td>21.00</td>
    <td>26.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>20.99</td>
    <td>145.00</td>
  </tr>
  <tr>
    <td>6562.50</td>
    <td>20.00</td>
    <td>25.00</td>
    <td>0.72</td>
    <td>1.00</td>
    <td>20.74</td>
    <td>145.00</td>
  </tr>
  <tr>
    <td>6656.25</td>
    <td>20.00</td>
    <td>25.00</td>
    <td>0.72</td>
    <td>1.00</td>
    <td>21.25</td>
    <td>151.00</td>
  </tr>
  <tr>
    <td>6718.75</td>
    <td>20.00</td>
    <td>26.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>20.48</td>
    <td>147.00</td>
  </tr>
  <tr>
    <td>6812.50</td>
    <td>19.00</td>
    <td>25.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>20.74</td>
    <td>150.00</td>
  </tr>
  <tr>
    <td>6906.25</td>
    <td>19.00</td>
    <td>26.00</td>
    <td>0.72</td>
    <td>1.00</td>
    <td>19.97</td>
    <td>147.00</td>
  </tr>
  <tr>
    <td>6906.25</td>
    <td>18.00</td>
    <td>24.00</td>
    <td>0.74</td>
    <td>0.00</td>
    <td>19.46</td>
    <td>143.00</td>
  </tr>
  <tr>
    <td>6718.75</td>
    <td>18.00</td>
    <td>26.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>2.56</td>
    <td>18.00</td>
  </tr>
  <tr>
    <td>6187.50</td>
    <td>35.00</td>
    <td>88.00</td>
    <td>0.78</td>
    <td>0.00</td>
    <td>1.28</td>
    <td>8.00</td>
  </tr>
  <tr>
    <td>5593.75</td>
    <td>45.00</td>
    <td>99.00</td>
    <td>0.14</td>
    <td>0.00</td>
    <td>1.28</td>
    <td>7.00</td>
  </tr>
  <tr>
    <td>5156.25</td>
    <td>45.00</td>
    <td>219.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>1.28</td>
    <td>7.00</td>
  </tr>
  <tr>
    <td>4718.75</td>
    <td>45.00</td>
    <td>219.00</td>
    <td>0.31</td>
    <td>0.00</td>
    <td>1.28</td>
    <td>6.00</td>
  </tr>
  <tr>
    <td>4312.50</td>
    <td>44.00</td>
    <td>219.00</td>
    <td>0.39</td>
    <td>0.00</td>
    <td>1.28</td>
    <td>5.00</td>
  </tr>
  <tr>
    <td>3968.75</td>
    <td>42.00</td>
    <td>219.00</td>
    <td>0.58</td>
    <td>0.00</td>
    <td>0.00</td>
    <td>0.00</td>
  </tr>
  <tr>
    <td>3625.00</td>
    <td>28.00</td>
    <td>219.00</td>
    <td>0.04</td>
    <td>0.00</td>
    <td>0.00</td>
    <td>0.00</td>
  </tr>
  <tr>
    <td>3312.50</td>
    <td>27.00</td>
    <td>219.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>0.00</td>
    <td>0.00</td>
  </tr>
  <tr>
    <td>3000.00</td>
    <td>26.00</td>
    <td>219.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>0.00</td>
    <td>0.00</td>
  </tr>
  <tr>
    <td>2718.75</td>
    <td>26.00</td>
    <td>219.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>0.00</td>
    <td>0.00</td>
  </tr>
  <tr>
    <td>2468.75</td>
    <td>25.00</td>
    <td>220.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>0.00</td>
    <td>0.00</td>
  </tr>
  <tr>
    <td>2218.75</td>
    <td>25.00</td>
    <td>219.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>0.00</td>
    <td>0.00</td>
  </tr>
  <tr>
    <td>1968.75</td>
    <td>24.00</td>
    <td>220.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>0.00</td>
    <td>0.00</td>
  </tr>
  <tr>
    <td>1687.50</td>
    <td>21.00</td>
    <td>220.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>0.00</td>
    <td>0.00</td>
  </tr>
  <tr>
    <td>1437.50</td>
    <td>14.00</td>
    <td>220.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>0.00</td>
    <td>0.00</td>
  </tr>
  <tr>
    <td>1250.00</td>
    <td>9.00</td>
    <td>219.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>0.00</td>
    <td>0.00</td>
  </tr>
  <tr>
    <td>1000.00</td>
    <td>8.00</td>
    <td>220.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>1031.25</td>
    <td>18.00</td>
    <td>220.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>1093.75</td>
    <td>22.00</td>
    <td>219.00</td>
    <td>0.02</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>2.00</td>
  </tr>
  <tr>
    <td>1093.75</td>
    <td>17.00</td>
    <td>220.00</td>
    <td>0.43</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>2.00</td>
  </tr>
  <tr>
    <td>1062.50</td>
    <td>16.00</td>
    <td>219.00</td>
    <td>0.74</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>2.00</td>
  </tr>
  <tr>
    <td>1062.50</td>
    <td>15.00</td>
    <td>220.00</td>
    <td>0.78</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>2.00</td>
  </tr>
  <tr>
    <td>1062.50</td>
    <td>15.00</td>
    <td>219.00</td>
    <td>0.82</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>2.00</td>
  </tr>
  <tr>
    <td>1062.50</td>
    <td>15.00</td>
    <td>220.00</td>
    <td>0.82</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>2.00</td>
  </tr>
  <tr>
    <td>1062.50</td>
    <td>14.00</td>
    <td>220.00</td>
    <td>0.86</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>2.00</td>
  </tr>
  <tr>
    <td>1062.50</td>
    <td>14.00</td>
    <td>219.00</td>
    <td>0.88</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>2.00</td>
  </tr>
  <tr>
    <td>1062.50</td>
    <td>14.00</td>
    <td>219.00</td>
    <td>0.86</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>2.00</td>
  </tr>
  <tr>
    <td>1062.50</td>
    <td>15.00</td>
    <td>220.00</td>
    <td>0.86</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>2.00</td>
  </tr>
  <tr>
    <td>1031.25</td>
    <td>15.00</td>
    <td>220.00</td>
    <td>0.84</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>1031.25</td>
    <td>14.00</td>
    <td>220.00</td>
    <td>0.84</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>1031.25</td>
    <td>16.00</td>
    <td>219.00</td>
    <td>0.82</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>1000.00</td>
    <td>14.00</td>
    <td>220.00</td>
    <td>0.78</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>1000.00</td>
    <td>14.00</td>
    <td>220.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>968.75</td>
    <td>15.00</td>
    <td>219.00</td>
    <td>0.68</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>17.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>14.00</td>
    <td>220.00</td>
    <td>0.04</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>13.00</td>
    <td>220.00</td>
    <td>0.04</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>13.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>12.00</td>
    <td>220.00</td>
    <td>0.10</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>12.00</td>
    <td>220.00</td>
    <td>0.39</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>12.00</td>
    <td>220.00</td>
    <td>0.70</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.72</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>12.00</td>
    <td>220.00</td>
    <td>0.23</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>12.00</td>
    <td>219.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>12.00</td>
    <td>219.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.04</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>12.00</td>
    <td>219.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>12.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>13.00</td>
    <td>220.00</td>
    <td>0.06</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>12.00</td>
    <td>219.00</td>
    <td>0.10</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>937.50</td>
    <td>13.00</td>
    <td>220.00</td>
    <td>0.16</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>2.00</td>
  </tr>
  <tr>
    <td>968.75</td>
    <td>11.00</td>
    <td>218.00</td>
    <td>0.68</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>2.00</td>
  </tr>
  <tr>
    <td>968.75</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.78</td>
    <td>0.00</td>
    <td>2.05</td>
    <td>2.00</td>
  </tr>
  <tr>
    <td>968.75</td>
    <td>12.00</td>
    <td>219.00</td>
    <td>0.80</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>968.75</td>
    <td>11.00</td>
    <td>220.00</td>
    <td>0.82</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>968.75</td>
    <td>12.00</td>
    <td>219.00</td>
    <td>0.82</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
  <tr>
    <td>968.75</td>
    <td>12.00</td>
    <td>220.00</td>
    <td>0.78</td>
    <td>0.00</td>
    <td>1.79</td>
    <td>1.00</td>
  </tr>
</table>
</body>
</html>
Well, at least can someone tell me the formula to convert EGRT to WBO2 so I could make these logs easier for someone to read. I remember seeing it somewhere on this site, but my search has revealed negative results so far.
well that all depends on what wb your running and how its scaled. Do you at least remember what your wbo2 said at ~6000rpm? because according to your nbo2 you are lean as hell! If you were actually seeing .76s on o2s Im surprised you haven't melted a piston! One of your sensors are faulty, you should first determine why that is...does the nbo2 cycle smoothy at low throttle with the wbo2 reading ~14.7?
I was going to say boost leak myself but that should register very rich nbo2s as well, unless his nbo2 is junk then a boost leak is definitely probable...I just found one in my intake the other day and it was causing some serious loss of power at WOT.
I checked for boost leaks prior to doing my pulls. I will check again...maybe something happened during the tests. My EGTs are ok though, unless that is faulty too. I'll look into recalibrating my WBO2 to see what happens. I'm going to pull the plugs too to see what they can show me at this point.
Plugs look good with a little carbon built on them already. Seems a little rich. I still don't know which gauge to trust right now. When I start the car, the gauge doesn't have a reading. It does it's calibration and then it is blank like it's out of range. However, when I start driving, at the low rpms, it shows about 17 which is what I like at idle (FTL=~120), but when I let off the throttle, the gauge reads blank again. At wide open throttle, I see the gauge go from 17 to the range of 9.0. Maybe the OEM O2 is bad, but it appears to cycle at idle correctly. I'll try another boost leak test today and post the results.
wooo your gauge says 17 during light cruising? just a heads up, just because your fuel trims say 120 doesn't mean you're any leaner then you are at 100. Fuel trims are designed to keep your car always running a 14.7:1 mixture at low throttle. The only way your WB should read 17:1 is if your fuel trims were maxed out (~140%), then the computer can no longer compensate for the miscalibration of the MAFT and will be forced to lean out.
Your IDCs are completely wacked as well! I also run 650s and at 20psi I only see about 70% IDCs. If your WB is correct at saying you are running 9:1 then those IDCs may be correct. I'd do another boost leak test anyways
Just a thought, but when you run your system really rich, the WB won't pick up on it, it won't read anything. Maybe you are running so rich that this is the case.
I have to agree. However, I did a boost leak test last night and found a small leak near the weld seam of my j-pipe. I'll have to fix it and retest. It's just a pinhole and I'm not sure if that would have this much of a drastic effect. I've had boost leaks before of a larger magnitude and it didn't screw things up this much. I'll keep checking. It's just once I remove the custom J-pipe, it's a pain to get back in since I can't get to the lower bolt easily. It'll take me a few hours to tackle just two bolts, a gasket, and a pipe.
I'd certainly start thinking about your timing advance with those bigger injectors. What are the specs on your chip?
My theory is that if you're knocking, and you add fuel, the knock lessons/disappears, but the car runs slow/rich, you've got - Heat soak, too much timing, or too much compression
At least, that's what I ran into on my car, mind you I wasn't running a chip either...something to think about.
I've pondered over the heatsoak issue since I have a modified Starion intercooler which is why my first 3rd pull is so important. I've recently removed the boost leaks and I'm still getting a descrepancy between the wide band and stock O2. The stocker is still reading lean and the wideband is reading in the 9. range at upper mid to high rpm. Now I'm starting to get knock at partial throttle. I don't know which sensor to trust now that my EGT has taken a dump. I'm not even sure if I'm getting real knock or not, the plugs look ok. My chip is set to cancel out the phantom knock. I guess I will have to run some race gas to see if I still get the problems. Maybe a knock sensor change will be in order, but the goop on the back of it is still intact. I did hear about filling the back of it with JB Weld, does this really work?
I'll post another log around July 6, 2007 while I'm off of work. Does anybody have some MAFT settings that worked for them? Remember, I'm chipped for PTE680's. (I'm AUX0 Base2, Idle5(strange), Mid2, WOT1).
I've been doing a fair bit of tuning lately, and can tell you this.
With my 450's back in (aka, stock timing advance due to stock airflow readings), at WOT my timing never goes past 11 or 12 degrees, and stays more like 8 or 9 degrees all the way to redline.
No knock to speak of, until I start rippin around at slow speeds - heatsoak.
I hate to :beatentodeath: but hopefully it's something you can look into a little harder.
Anyone else have timing logs on their WOT's available for this gentleman?
Hmm, thank you for the reply. I may have to mess with the MAFT settings to see if I could bring my timing down or at least lock it in. My base is set at 3* for safety which is probably why I haven't blown a head gasket yet. I need to find someone in my area that can assist with this tune and who has a MAFT. I really wish I invested in DSMLink. I think this whole mess is a timing issue compounded with heat soak. Even though the stock O2 states I'm lean, I do smell a rich condition as demonstrated by the wideband.
One more problem (could be related), anyone with a VR4 and a chip for stock boost gauge to knock gauge conversion: do your led lights flash either half way across or all the way across when the key is turned on in the ignition in preparation to start the vehicle? Mine does both sometimes. I just want to make sure that I don't have yet another electrical problem which may be messing with the knock sensor. This car's electrical system has been a nightmare from the prior owner.
I would trust the wideband over the stock O2 everyday of the week, if it's installed properly.
Secondly, if we look at the causes of knock, we can get a better picture:
Timing too advanced
Fuel conditions too lean (or too rich in the rare circumstance)
Compression too high
Intake charge too hot (heat soak)
Latent heat of spark plugs (Remember the number in the plug rating refers to the plug keeping temperature throughout the cycles of the engine, and is not a measure of how hot the actual spark is. In other words, if you're running a hotter plug( a 5 or a 6) it will retain heat from the compression stroke through to the next compression stroke)
Electrical/Knock sensor issues giving a false reading (which isn't real knock, but the datalogger will see it)
From my experience, the 7's(plugs) should be fine, but maybe jumping to an 8 would be a little better for the WOT. It will hurt your idle/low end a LITTLE though.
Base timing of 3 degrees is conservative.
I would try some race gas to make sure it isn't an electrical issue (or try the Toluene trick), and go from there, but I think you hit the nail on the head -- Timing and heat soak.
if your car smells rich, you probably are just that...however our cars will usually begin to cut once in the 9:1 AF range. does the car still pull smooth or do you feel light misfires from an over rich mixture. Im just having a look at the stock fuel map on our cars. Assuming you do not have extended load range maps on your chip, your timing is bang on what it should be for a 1g. with the stock load range maps, as soon as you go above ~2grams/rev of air (or about 15 psi), your computer can no longer reduce timing or AF. This is why stock computers blow for tuning unless you extend the load range...then you can tune to roughly 30psi. So if you're running say 20psi at average intake temps, you're technically running the same amount of timing as you would at about 15psi. What is your charge pressure?....
long story short, if your wideband reads rich and you're confident its correct then ignor the stocker. The stocker has no effect on performance at WOT. Also MAFT setups are a pain in the ass period...if I were you, do what I did...get an eprom emulator (175 bucks), sell the maft for $200 and tune the stock ecu yourself and just run a 2g maf or ds-map (speed density). Your car will thank you...its so easy to tune and makes your car run so smooth because you're reprogramming the way the car thinks rather then just compensating.
