tuned for 93 octane, but moving to 91 only area.
henrysan
212
24
Feb 20, 2014
wichita, Kansas
running a garrett 50 trim with full supporting mods, currently tuned for 93 octane at 21 psi. will be moving and only 91 octane available at stations. e85 is available but not sure if ready to make the switch. will the car be ok for a while with just lowering boost to run 91 or would a re tune be mandatory?
I'd just tune more conservatively for the 91 in the meantime. Lower timing advance and maybe a little easy on the boost. Just until you switch you E85. Yes, you really want to switch to E85. You'll wonder why it took you so long to do it.
Look around for pump 100 and add 3 gallons to each tank when you fill up. It's annoying but at least you have the correct fuel until you retune it.
Meth injection will solve your problems for sure. We only have 90 octane in Alaska so quite a few people go the meth route.
