tune up help
turbox
Feb 19, 2007
rlsinore, California
ok i bARELY CAME UP ON A TALON 95 AWD TURBO.....I WANNA GIVE IT A TUNE UP....### PARTS SHOULD I BUY BESIDES THE BASICS LIKE OIL,OIL FILTER,AIR FILTER,SPARK PLUGS AND SUCH AND ### KIND OR BRAND DO I USE LIKE FOR OIL I HEARD AMSOIL 10W 30 WAS THE BEST BUT I CANT FIND IT ANYWHERE WERE CAN I GET IT?
Also, Magnacore spark plug wires, Red Line fuel injection cleaner, flush the radiator, new factory thermostat and radiator cap, new factory fuel injector seals. Depending on how many miles, replace the o-rings in the throttle body, it's easy. When you're all done, you'll have a fine running maching. Also, do a boost leak check. Finding and fixing leaks will make a world of difference! As for amsoil:
http://www.amsoil.com/StoreFront/default.aspx
Use 10-30W with a higher mileage motor.
