1G Tune help OBD1 in black box ECU?
HaulinTSI
48
Nov 23, 2003
TAMPA, Florida
I have a black box ECU, 2g MAF, in a 1g Talon with OBD1.
How can I flash ECU to tune with the OBD1? Will it work?
Solution
When you converted the harness to plug in the 2G ECU you should have attached a ODB2 connector to the harness and connected it to the ECU so you could talk to it.
i think you may need an evo 8 ecu to flash tune in a 1g but i could be wrong. you do not have the required OBD2 plug under your dash as the 2gs do. As well as the flash port connector that sits next to it. in the case of the flash port connector it is possible to hard wire that into the ecu
