TT with wbo2
To answer your exact question, As long as that ''turbo timer'' comes with a wideband o2 sensor, You will get accurate readings. Never count on a narrowband a/f ratio gauge to give out correct or useful information, Though. I believe that item does come with the actual sensor, Though. It says it's included, Unless I am reading the description in the link, Incorrectly.
You do not need a turbo timer though, To be honest. Let your car sit for a few seconds before shutting it off (after ''beating up on it''), And you will be fine. Or, You can easily just drive ''normal'' a few minutes before your destination, And you'll be OK, Aswell.
With not getting a turbo timer, Or the specific kit in the above listed link *which does seem like a great price if it comes with the wideband sensor*, You could easily just get an aem wideband kit for $200, And save over $50+ shipping, If you wanted.
