tsi cuts out at boost
zeekster777
523
Dec 31, 2009
valley center, California
ok so my 1990 tsi runs good idles a little high but all in all its smooth, that is until i really get on it, it seams like it falls on its face as soon as it gets over 4psi boost, could a leaky caps in the ecu do this ??
My car did that when I first started to tune it. It was running really rich which caused that. Also could be the plugs or wires. You could take the ecu out and look at it. You can tell if the caps are leaking.
ya i just put in new plugs and wires. It didn't help at all, ill try the boost leak test thanks.
+1 on the boost leak test
Mine did this same thing a couple years ago, turns out I had a massive tear on the underside of the soft pipe coming from my throttle body to the BOV.
Clogged fuel filters can do this same thing as well.
Boost leak test dude. If you would use the search function, you would find there are 565,546,345,465,001 threads pertaining to the problem at hand.
so i did a turbo leak test and its good. So i swaped out the ecu with the one in my 1991 gsx, it runs really good above 2500rpms but it really idols like crap and it has really bad throttle response, its like the exact opposite,
Could be a few things caps leaking/mas/tps i would start with the mas try to find a 2g mas it solved my problems!
Slow91laser, thanks but I did all that and its still not working, did you look at the whole thread?
Could be a one of many things. Look at the cheapest solution first and work your way up. But yes, caps could cause this.
its not the caps i have 3 ecu i have tried but hear are the pics of the 1990 ecu,
Picasa Web Albums - zeek coates
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/IpY0cGPSlX8iuuKXeJnJ4aL-ZqgQeKq3VQAQdRluw4E?feat=embedwebsite"><img src="http://lh5.ggpht.com/_5gb07DlBZOE/TQ0PripR_3I/AAAAAAAACiI/B_LVNTgWDQU/s144/IMG_20101218_114531.jpg" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/lh/sredir?uname=zeekster7777&target=ALBUM&id=5438648874333637281&feat=embedwebsite"></a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/kYkPdyzjWkCIEb8DqCNy7aL-ZqgQeKq3VQAQdRluw4E?feat=embedwebsite"><img src="http://lh5.ggpht.com/_5gb07DlBZOE/TQ0RB5AE7xI/AAAAAAAACiM/U9wZHS96zQ0/s144/IMG_20101218_114510.jpg" height="108" width="144" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/zeekster7777/DropBox?authkey=Gv1sRgCLf2rYm_jPPoPw&feat=embedwebsite">Drop Box</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/LEXIvAV2SuWd3IWMMwV5_qL-ZqgQeKq3VQAQdRluw4E?feat=embedwebsite"><img src="http://lh3.ggpht.com/_5gb07DlBZOE/TQ0ROWqUbwI/AAAAAAAACiQ/Ffijc4yuBBc/s144/IMG_20101218_114504.jpg" height="108" width="144" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/zeekster7777/DropBox?authkey=Gv1sRgCLf2rYm_jPPoPw&feat=embedwebsite">Drop Box</a></td></tr></table>
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/HJS0JmPABpWDwSXOPUWJfqL-ZqgQeKq3VQAQdRluw4E?feat=embedwebsite"><img src="http://lh3.ggpht.com/_5gb07DlBZOE/TQ0Rd2-mFXI/AAAAAAAACiY/9Q3CaTcd8ZE/s144/IMG_20101218_114455.jpg" height="108" width="144" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/zeekster7777/DropBox?authkey=Gv1sRgCLf2rYm_jPPoPw&feat=embedwebsite">Drop Box</a></td></tr></table>
im having the same dang problem after my 6 bolt swap i feel your pain i cant even go pass 80mph
but like i said when i use my 91 ecu it runs good at top end, and when i use the stock ecu it has no boost it just cuts out and falls on its face, im going to do like every one said and swap out #6 & #14 pins on the ecu plug and see what happens, i think its the ecu, but like i said it works in my 91 gsx
wow steve you truly know your stuff. Thanks again. that was a cool link
haha yes, it runs really good. I swaped out #6 & #14, my tack isn't working but it sure runs good. Thanks for all the info.
