UMR98GSX
- 478
- 7
- Oct 26, 2004
Newport Beach,
California
A couple of weeks ago my car began to completely cut out for a split second under partial or no throttle while cruising. It does not cut out under WOT. I began checking the normal things: plugs, wires, ignition coils, etc. Everything ignition related was within spec (the ignition coil was at the upper end of spec). I replaced the plugs with a set of new freshly gapped bpr7es's just in case.
I recently installed my new wideband and it confirmed that my problem was with the fuel system. Whenever the car cuts out it reads off the charts lean. My first thought was a clogged fuel filter. I am running a -6 an Earls inline with the 35 micron sintered bronze element. I changed the element to no avail, it still cuts out intermittently.
My logs on Link don't tell me anything that I don't know
Whenever it cuts it just reads ridiculously lean but inj duty and everything else reads normally, front O2 is functioning, etc.
I have not run a boost leak test yet simply because it is not acting like there is a leak anywhere in the system or that it is sucking in unmetered air.
My profile is up to date...any ideas?
