ECMlink TS HX40 pro/E85/25psi - How's it looking?
abaum565
266
3
Aug 9, 2006
Wausau, Wisconsin
This is the first time I have taken it to 7.5K rpms in a while, and since switching to SD. I need to smooth out my VE table a bit too.
I blew the water pump belt off on this pull and once I got it back on I got another log with some adjustments to take out that knock and fatten the AFR's up some more on spool up, but I only took that pull to 6k as I am on a 2 belt system with the alt relocation kit. I need to move to a 3 belt system as the belt doesn't seem to line up correctly they way I got it from Jay racing.
Anyway, it seems to pull pretty good, I wish I could get some more timing in there, especially on this fuel. But I will keep working at it.
Any suggestions? It's a work in progress, I haven't done much WOT tuning on this setup yet. I feel like it should be flowing more air, but I know these things like to wake up at higher boost levels.
Major mods should be updated in my profile - but it's a true twin scroll hx40 pro in a 16cm^2 housing on E85 with a single wally intank for now and BM1550's.
The one thing that pops out at me is from the start of the log to about 4k, your Wideband doesn't quite match up with AFRatioEst. There is a pretty cool tool I have been using to smooth out my VE table on the ECMLink forums. You can find it here: ECMTuning User Support Forums
Once you make a few runs through that, it should smooth that out a little. After 4k, it looks fairly good. Your VE table looks about as spectacular as mine haha. I think you might be making too big of jumps from cell to cell, but I will let the more experienced members chime in on that. :D
