ECMlink My first tune. How's it look?
gixxer6
60
5
May 28, 2012
Kingsley, Michigan
This is my first "tune". I am new to DSMlink, so be gentle... Please take a look at my tune and tell me what you see. Everything look as it should???
1. My 1G crushed BOV is not holding my boost. No boost leaks or exhaust leaks.
2. I have not had a chance to verify timing.
3. Ignition system is good.
4. Stock motor has 105K miles, with no know issues
5. Throttle body is rebuilt and adjusted.
6. Stock fuel pressure regulator (37psi)
7. Fuel pressure and injector values set.
8. Stock compression ratio 7.8:1
9. No know wiring or sensor issues
10. New AEM UEGO installed and logged (also built and installed the buffer circuit), WB gauge appears to match DSMlink display
11. 93 premium
12. No codes
13. I have watched the videos a few times...
The car seems to run ok. I ran a 9.04second 1/8 mile last weekend. It idles ok, and pulls hard at wot. It puffs black smoke while in open loop and not at WOT. My dead time is set at 465, but everything I read says it should be closer to 330. I'm not sure why.
Please take a look at my log and tell me what you see... I've been reading, and reading, and reading, and reading, and fixing, and tweaking, and reading more... I'm doing my best to learn as much as possible. Thanks!
