trying to stop engine smoking. Need Help!!!!!!!
alienauto
Nov 20, 2003
I have a 1990 talon turbo. I bought the car the car not running and all it needed was an ecu to make it run. But now I'm having a problem with it smoking. It only smokes at idle and it gets worse with a load, like having ac on. Help please. Thanks in advance.
get some smoke away or maybe the car already has lung cancer. would be nice if you did some simple checks, compression etc etc. or better yet let us just guess cuz every motor smokes for the same problem.
by what you said i have it narrowed to about 5 things
rememeber vague question = vague diagnosis
we did do a compression test and it came out great. About 160 across all 4 cylinders.
We think it to be either turbo seals or valve seals or ?
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
