Trying To Get a Motor Together
SPOOLISH93
Feb 21, 2012
Waco, Texas
I've got a 88-89 block with a welded crankshaft(weld is around the thrust washer), a head off of a who knows what year (possibly 95-96) with no cams, gears, or cam towers. My buddy took it half way apart and lost some of the hardware and other misc. items. So as you can see I didnt start off with the best stuff. I tore it all down and took it to my engine builder, he said it needs a crank and possibly pistons since the rings are pretty gummed up on them.
I've also got another block available from the same friend I got the one above. But it is also half way tore down with parts scattered across the back yard. He is unsure of the year but he thinks its a 95-96. It has crankwalk, no big deal if the block or crankshaft is still in good shape. It has a complete head but he said it has a crack in it but it does not leak or effect anything?
Questions so far are, will a 95-96 crank work in a 98-99 block with no modifications? Are the heads any different from 95-96 to 98-99?
Looks like I just need to find a whole nother complete engine, or at least a good complete cylinder head and a crankshaft. This is turning into more of a hassle than I planned for.
The head missing the cam tower caps is now junk or to be robbed of the springs and valves if needed to fix another head.
A 7 bolt crank is a 7 bolt crank, it matters not if the factory set it in with thrust washers or on a saddle bearing...
Yes the heads will interchange with one another.
Ok so I found a seemingly nice complete motor that has BC 280/280 cams. Am I going to have to do some tuning to get that to run right?
He is including bigger injectors but I figure I just use my stockers with the stock ecu so I wont have to do tuning as of yet, is that going to be a problem with those cams? Im running stock turbo at 17psi
Im not looking for a monster drag car or anything, just a fun daily driver and a weekend racer.
Yes, he is inculding adjustable cam gears. Here is what hes got:
I may buy for $1850 This would be going in my 97 GST Automatic. Just looking for a super fun daily driver and weekend pony killer. A friend of mine has talked me into getting a safc.
4g63t 7 bolt BUILT long block motor never installed into car
all ARP connecting bolts (head studs, con-rods, main bolts),
eagle forged crank,
eagle h-heam rods,
wiseco 9:1 compression pistons,
gates racing belt,
balance shaft elimination kit,
adjustable cam gears,
brian crower 280/280 cams,
brian crower titanium valve retainers and springs and cometic head gasket.
ALSO, will come with: Aeromotive fuel rail,
PTE 680 injectors,
first gen intake manifold w/ Throttle Body and ignition coils,
14B turbo,
power steering pump,
alternator,
magnus external oil cooler.
Spare valve cover and misc. parts
Sounds alright. But was any machine work done? Just skeptical because he still has a cometic headgasket on instead of a steel one. If no machine work was done on the cylinders, the rings will never seat.
You mean just honing? Or boring? I would imagine, but I will ask. He said his brother's friend worked at a machine shop and checked everything out but he didnt give details.
He said it was plastigauged and checked to be in spec by the machine shop and they honed/crosshatched the cylinder walls.
