DSMDEMON93
- 319
- 2
- Feb 18, 2009
San Jose,
California
Hey guys, so for the past few days I have been trying to dial in my AEM UEGO wideband with the DSMlink, but am still having a little trouble. I am always off by at least .3 Lambda at some spots. Here are a few questions I could not locate via the website.
-I set up my wideband using the ECMwiki, setting it up as the LinWideband, and picking the mounting location(i.e. front 02, rear 02, etc) Here is the issue. I have a wideband bung BETWEEN those two spots, so where should I tell the ECU where the signal is coming from? I chose the rear 02 and wired it into the rear 02 pin on the ECU, but I'm worried that this will cause a inaccurate reading.
Also,
-While calibrating the gauge, a How-to video posted by a member, stated to turn the vehicle off, while link is running, and watch the WB02 hold a constant reading, and use that as a reference point. When I do that, it keeps moving around, as if the vehicle is in a closed loop cycle, it does not hold a constant reading, and eventually..fades off to "---"
When Calibrating the wb02, do I need it to match up the ENTIRE time on link, or just during WOT pulls(dumb question, but curious)
Please let me know! Thanks!
Also,
