ECMlink Trouble logging Omni 4-bar MAP sensor
hofmania
91
Apr 18, 2013
Berkeley, California
I've got the plug n play SD cable installed as follows...
Omni 4-bar sensor connected directly to the intake manifold via 1/8 NPT tap
IAT sensor screwed into a welded bung 6" from the TB on the FMIC tubing
Connection to the MAF sensor.
Here is how I have things mapped in Link
And for whatever reason, the baro reading on my data logs is always 30.1hg. It just doesn't change. What have I done wrong?! :banghead::ohdamn::hmm:
You need to go to captured values and select omni 4 bar to be captured then go to displayed values and select omni 4 bar to be displayed.
So the "Baro" value isn't actually the one I need to display? :ohdamn:
If this is the case, I'm all for simple dummy fixes.
