TRIMS won't set with Stg 3 EPROM
eclipsh
1,608
65
Jun 16, 2005
Durango, Colorado
I've been going back and forth with Jeff to try and figure out why with no avail.
Along with the EPROM chip I installed a set of FIC 780cc injectors and a 3g MAS with an adaptor soldered in for plug & play compatability.
http://otsmotorsport.com/dsmchips/viewtopic.php?p=2165#2165
I started out with a set of 680 RX7 injectors and one FIC injector and switched to a full set of FIC's. The chip has been reprogramed for the FICs.
I have tried tinkering with fuel pressure (gone as high as 50 psi Base) with no effect on trims setting.
I get huge knock if I go above around 30-40% throttle or 14psi.
Any ideas as to why this is happening would be of great help.
Settings on the chip are as follows:
Sutterbox
No fuelcut
CE shift light at 7k
Knocksum Gauge
3g MAS
A/C Cutout at 85 % Throttle
FED/AWD
43 PSI AFPR Base
10.0:1 WOT A/F
7500/6000 Selectable REV limit, Resets to 4500 on cold bootup
Full Octane
Enhanced Closed-Loop MAPS
750cc Injectors/288uS Deadtime
750 IDLE
Inverted Cyclone on Purge Solenoid (due to actually having the JDM solenoid)
No Airflow Cap
Rescaled Trims
2X Karman
Anti-Stall code
I've also noticed that if I build boost slowly up to 15 psi knock isn't a problem. If I try to build boost quickly I get massive knock counts (15+).
