DSMKevan
- 491
- 0
- Mar 19, 2004
Clarkston,
Michigan
I just tried the BISS asjustment faq http://www.vfaq.com/mods/BISS-1G.html by grounding both the terminals, and tried to start the car. It sounded like it was going to start for a second then just didnt. I heard no noise of the engine trying to start, just rapid clicking from the rear of the car as well as from the ECU. What the hell just happened?
Ive also been experiencing symptoms of the car dieing or stalling (all the lights flash up on the guage cluster), but this happens while I am a little bit through a turn. Each time it has happened the car has not been in neutral and the clutch pedal has not been depressed. It happens around 2-3k rpm and about while the steering wheel is at 8 or 4 o'clock (dpending on if you turn right or left).
Could I have grounded the wrong thing? Could I have grounded a plug on the diagnostic plug that wasnt supposed to be grounded when starting? Or is it the matter of a small fuse? I tried reverting everything back to normal and it still does the same thing....
Please help.
Please help.
