Transmission to block seal! Help me find this part!
spoold
260
4
Dec 20, 2003
Indianapolis, Indiana
Ok after dropping the tranny (putting a new crankshaft in the car, thanks to some spun bearings), the thick metal seal between the block and the bellhousing that is shaped like a half moon is cracked in numerous places. I searched for a gasket but cannot find one anywhere?
Can anyone help me locate this gasket? i cant even find what it is called?
Its actually the piece on top, not the flywheel inspection plate. but its in the same place, just at the top (has a hole in it where the starter goes through)
Rear Cylinder Block Plate - MD194962
About $11.26 from a dealer that offers a 25% DSM discount. Also, try JNZ Tuning.
Junkyards probably have these also.
Mike
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
