help me find this part
tony_tsi
61
Jun 18, 2007
Cavecity, Kentucky
Ok at one time long ago I bought this o2 houseing
I cut off the dump tube grinded down the flange and welded a flat piece of metal over the hole. I did this b/c my external wastegate is on my exhaust mani. Long story short it was slightly warped had it surfaced at a local shop then put it on. I have seen one somewhere b4 that had the internal gate blocked by the o2 flange now I cant find it anywhere dose anyone know where I can get this?
Your talking about having your turbine housing wastegate flapper welded up? Its not that clear...
I do not have an internal flapper. I do not want to weld up hole where the internal flapper would be. i want a o2 housing that solves this prolbem.
I want this with an elbo and a flange to connect to the downpipe
Well get that o2 housing in the pic, cut the o2 dump off and weld a plate in the hole. Better use a good gasket, since the pressure will still build in there.
that is what I did the heat from the weld made it slightly warped so i had it surfaced at a machine shop then I put it on my car. I want a new one that is not welded closed I want one that is made that way. some one makes them I have seen them b4 i just cant find them now.
he wants a mitsu o2 housing but made for external wastegate
i want a mitsu o2 housing made to block an internal wastegate my external is mounted before the turbo it is on the exhaust manifold
a complete o2 housing that uses this flange
yes that is exactly what I want
No man, but post is listed in my town aria so I looked up local Craigslist and found what you want ;)
I can go look at it and even shot the little video of the part... upload it to youtube or something...
i just called him he dosen't have pay pal so i dont know what to do
your awsome man thanks!!! let me call him back and see if he will take a little less since it is an obo what do you think I should offer him
Oh yah! Look what I got here! :)
