Transmission Seals
Yes but you need two of one. tcase output from tranny and tcase input are the same part number. The input shaft seal also goes inside the transmission. Unless you're tearing the transmission down you can't install it. Are you doing a clutch or a tranny rebuild?
you need the the t-case input shaft and output shaft seals if you want to change them. The seals for the tranny are both axels seals and if you want to, the out put shaft seal. The tranny output shaft seal use the same seal as t-case input. A little confusing.
