Transmission Seal / Gasket.
jenglish1984
50
May 21, 2008
Fort Smith, Arkansas
I am loooking for a seal or gasket for a transmission + transfer case.
I'm having my car re-built and I need a gasket that goes on the transmission (between the engine and tranny), and also a gasket that goes inbetween the transfer case and tranny.
ALSO... I need the seals that go from the front axles to the tranny.
Does anyone know where I can order these + what the part numbers are.
Thanks,
Jamie
There is no gasket between the engine and trans, there is also no gasket between the trans and tcase. The output shaft from the transmission to the transfer case does have a seal. There is also a seal on each side of the trans for each axle. You should be able to get most of the seals from autozone, napa and of course the dealer.
