2G Transmission Leak
Thugmaster1220
74
Oct 26, 2011
Woodstock, Illinois
Hi everyone!
I've got a 97 gsx awd automatic that's dumping out trans fluid.
Since I'm not much of a trans guy, I'm wondering what are the possible places you can leak trans fluid from?
I see a lot of people have issues with it leaking from the transfercase. That is not my issue. I can physically see it coming right out of the trans.
I dropped the trans once and replaced the seal the torque converter sits on, I believe it's referred to as the input shaft seal.
Now I'm not sure what to fix next. It does not leak when the car is parked. Only when you turn it on and move it through park/reverse.
If someone could tell me what other locations in the trans could cause this that would be very helpful? I have hunch that it's torque converter, could that be it?
