1G Transmission issues, please help!
Sbgriffin
187
18
Jun 14, 2017
Lewiston, Idaho
So my 1g DSM fwd is starting to have some significant shifting issues. Locking me out of 1st, crunchy shifts, etc. So I'm sure my synchro's are trashed. Also I should state, I've replaced all my clutch hydraulics with new OEM. Made sure I've bled the piss out of it. Also have changed my transmission fluid twice with redline mt90, then decide to try mt-85. Trying to wish the problem away. But it's getting worse. Also it's a lot worse when the car is cold, gets better after 10-15min of driving. So I was thinking about trying my luck with rebuilding, but after reading the vfaq's write-up, no way I'm signing up for that. So where can I find a decent used, or remanufactured f5m33 transmission for a descent price? Thanks.
Yeah I've tried til I'm blue in the face. Probably 15 times, doing small adjustments. I've tried Jafro's method, Jack's transmissions way, and several others I've read. Never can get it exceptable. So the only other variable is I'm regretting my clutch choice. At the time I was pretty broke, and decided to go with an XTD stage 2 clutch. Big mistake I know. So is it possible that my garbage clutch could be causing me grief? I'm considering buying an exedy OEM replacement, what's your thoughts on this? Also keep in mind I'm only wanting 250-275whp, and would like to have a lighter, easier to use clutch.
I've tested the pedal assembly, there's really no play. I think it always had a stock clutch, so didn't wear out anything. And I tried the clutch drag test several months ago, I guess I should try it again since I just replaced my hydraulics. I really feel like my garbage XTD clutch might be contributing to the issue. Since day one I've had nothing but problems with it. Engagement is near impossible to master, always shudders hard, rarely can find that sweet spot. It's definitely the worst clutch I've ever used, really kicking myself for going cheap.
But I'm thinking of trying my luck with the overhaul. I know I'll have to hire out on parts of it, I don't have a press or several tools needed. Also the end play is critical I understand, so I'll go to my trusted machinist for all that. Hopefully I'm not getting in over my head. I've rebuilt several engines, never any transmissions .
I think this sound more like a clutch issue than the tranny. I didn't see any mention of your flywheel & step height or clutch fork position in this thread. When you installed your XTD what step height did you measure &, per the different video & clutch methods, where your clutch fork position in the bell housing window?
If you've done motors you're qualified to do this. Still sounds like clutch.
When I had my flywheel resurfaced I asked for .610 if I remember correctly, not sure how close he got to this though. And the fork looks like it's positioned well, close to center. Maybe a few mm towards the drivers side. So I didn't shim the pivot ball. So I'm considering pulling my trans again, replacing the XTD for exedy, an OEM throw out bearing, and making sure the flywheel is setup correctly. But it's gonna suck if that doesn't fix it, then I'm still in the same boat. Just a few hundred dollars broker. What do you guys think?
