Transmission Bolts
adamsdarin
30
Dec 21, 2004
La Porte City, Iowa
Im missing 2 bolts that mount the transmission to the engine. Im also missing the nut that goes on the transmission mount. Anyone know the size of those parts?
You need to provide more information.
Automatic or Manual?
Which bolt hole location on the transmission are missing the bolts? (CAPS shows 5 bolts securing the transmission. 2 are the same size. The other 3 are different)
What is the location of the nut? (CAPS shows all 3 nuts having a different part number)
I wish I could figure out how to post diagrams from CAPS into my posts. Anyone?
If you want to download the program:
http://www.stealth316.com/2-wincaps.htm
It has great diagrams and makes finding sizes and part numbers easy.
Mike
M8 x 1.25
Keep several lengths in your parts bin. They are used all over the car.
Mike
printscreen > paste in photo editor > edit photo > upload to photobucket.com > post here with the provided bb code links that photobucket provides under images.
Hope that helps, sorry for the slight off topic.
M8 x 1.25
Only one bolt for securing the transmission to the engine is M8. The other 4 are M10.
You don't get banned for correcting a moderator, do you? :D
Mike
Thanks bling5tatus.
I will look into it.
Mike
If this worked, it is a diagram from CAPS for a 2G manual transmission. This is looking at the back of the transmission towards the engine.
adamsdarin,
If you have a manual transmission, tell me which bolts your missing and I can provide the info you requested. If you have an auto, I will have to provide a different diagram.
Mike
Here is the diagram for the nuts.
Mike
