Transmission? 0.0
DeanCorleone
44
Mar 20, 2004
Frederick, Maryland
Hey guys, I got a 90 Plymouth Laser FWD, guy I bought the car off of for 1K, said he just put a limited-slip (MX, MB, BX onea them, the cheaper one.) and rebuilt it... when the cars cold, it doesn't want to go into gear, first or second. I get feed-back and grinding. (as if the clutch wasn't pushed it and I was trying to shift into gear without a clutch.) This problem disappears and the car operates normal once its at running temp... Don't smell the clutch burnin' or anything, just figure'd I would get some imput from your guys.
I might have to adjust the clutch is all I'm guessing, its really hard in, almost at the bomtton of the floor is when it starts to engage. OMG
Yeah - you may want to check/bleed the clutch master and slave cylinders. Make sure all air is out of the lines, and that there are no seals leaking.
LSD is likely to be the BMTranny unit.
