v8s_are_slow
- 2,824
- 280
- Sep 30, 2002
Panama City,
Florida
just got my dsm chip and it's burned for 650's. now someone told me to set my translator for 450's. um okay. but why??? i'm running 650's. i've set it to 450's but since, have pulled it all the way back to 580's on my translator and it seems as though i'm still running rich. cause i know i'm rich at 450's. no knock, egt's only get to 1400 max!!!
anyway, can someone tell me why i'd need to set it for 450's? cause i'm not tricking the computer anymore i wouldn't think, using this new chip. anyway, someone help me out here. i wanna set it to 650's but wanna make sure i'm not gonna run too lean. thanks!
scott
scott
. Set your MAFT for 450's so it will send the ecu the proper signal for the amount of air mass that is actually occuring. Then your ecu chip will compensate the fuel and timing and scale for the injectors accordingly. Fine tuning adjustments can now be made from their. Also make sure your base fuel pressure is set properly unless you are using it as a tuning tool.
