Transfer Case for a 93 TSI Compatiable with 2g Transfer Cases?
As long as the spline counts are the same it will bolt up. I can't remember if there's a gear ratio difference in the Automatics from the Manual so you better make sure they're the same too.
Rick - '91 GSX :dsm:
Outer casing is same for 1g 2g. (early 1g came with an aluminum gear housing)
All 2g's have 23splines, 1g came with 22~23 depending on make year.
Auto and manual t-case are different both in shape and gear ratio.
1g& early2g(-'96) have different gear ratio compared to '97-'99.
I think that sums it up. The 2g tcase will bolt on but only the pre '96 will work without loading your center diff.
-treebonker
