Transfer case and diff fluid help
GettinPaper
289
Aug 31, 2009
Battle Ground, Washington
You will be more than fine with what comes in that fluid kit. The most important thing is that the fluid for the transfer case and rear end are GL-5. I have had no issues with the fluids in that kit. Since you already purchased it, just roll with it. You may want to replace the crush washers on the plugs for the transfer case and rear differential. Extrempsi and JNZ have them.
Damn, I didn't know I needed to replace them, should I hold off on doing the fluid change till I get some new crush washers?
