Transaxle Mounting Bracket Bolt Specs
mrxios
Nov 5, 2009
wayne, West Virginia
1993 Eclipse 2.0 non-turbo FWD
My friend just got this car and we noticed both bolts that attach this bracket to the transaxle are missing.
Does anyone have the specs for these bolts?
The bracket is the one on the passenger side, below battery, one side of bracket is attached to wheel well, it has a large rubber bushing. The two bolts that are missing are the ones that go through the bracket into the transaxle.
Thanks for any info.
not sure on the specs, but make sure you take care of it quick, cause if the mount isnt holding it properly then the entire motor could shake ridiculously hard and cause body damage around the mount and possibly damage the transaxle
For a quick fix, you can lift up the back bottem seat and take the two bolts holding the seat belt bracket in the middle.. They are the same size, and then find bolts to replace them..
