2G ECU mounting bracket tabs missing?
boostjunkie24
Oct 15, 2014
Erie, Colorado
I have a 95 ECU for my 97 GSX since I am switching to DSM Link. I have the ECU mounting bracket but my car does not have the tabs the ECU mounting bracket bolts to. Does anyone have or know what the part or tabs are called that the ecu mounting bracket bolts to. I tried miller Imports and everything but cant find out what I need to mount my ECU and already have the mounting bracket but am misssing the part with the tabs the bracket bolts to.
What am i missing?
your missing this one?
Yes. My 97 GSX had an AEM standalone in it when I bought it. I decided to switch to DSM Link. I bought the ECU and the ECU mounting bracket and then realized there were no tabs to mount the ECU mounting bracket. Do you know where I can purchase those or what they are called.
I wanted to mount the ECU properly.
Thanks alot nobody seemed to understand what I was missing
i should have one somewhere. im looking for it now
Do I need two of them one for each side? I didnt want my ecu moving around. I have been working on my Eclipse for 1 1/2 years niow and am dying to finish it. I am dredding the DSM link install and speed density conversion. Getting the car set up for E85 now. I have an FP green but just finished installing some GSC S2 cams and have a Magnus cast intake coming and want to finish the car. Its my first DSM so I have been learning alot along the way.
That is the ecu mounting bracket. I bought 2 of those already thinking I bought the wrong one. The problem I am having is that there are no tabs to mount the mounting bracket. Does your car have tabs that the ecu mounting bracket bolts to. Since I bought my car this way I have never seen an ecu mounted in the car.
I am confused so how is that mounting bracket secured. I have 2 of them am I just not getting how the mounting bracket for the ecu is secured?
drivers side i drew white arrows where the bolts go
passenger side
red is where the ecu bolts to, blue is where the bracket bolts to the other brackets
What am i missing?
I would go to a junk yard should be easy to find
