Trans Rebuild - Click, Grind, Shop
Slammed0
185
Nov 26, 2004
Boise, Idaho
So I got my transmission rebuilt. I went to Aamco. I know I know what most of you are gonna say, but that part is already done and over with. Anyways, my questions are....
1. I have a clicking noise when I take off or back up. Only does it then. Not during regular driving time. They thought it was from my suspension. However, I have replaced my struts and had my suspension looked over a few times. Also, it only appeared after they installed the tranny. Now its going back for warranty, but I just wanted to see any ideals of what if may be.
2. A brand new rebuilt tranny. Should it grind at all in higher RPMS? It works just fine but I noticed in 2nd gear when I am in higher RPMS (6-7) and I shift it still catches a little bit. Thats the only gear. Maybe they just use cheap oil? Cause sometimes in the mornings its a little sticky shifting too.
So, lesson learned here with the shop. Lets just hope they can fix all this without a hassle.
Make sure the transmission fulid you are using is straight from the dealer.
Manual-transaxle fluid from the dealer, nothing less, made for our cars.
Expensive yes, but worth it yes. You only need about 2.1qt.
Clicking could be alot of things. Does it happen in just a straight line, or around corners as well?
Good question. Mainly straight lines, however, I thought I heard it click once on a turn. Can't say for sure though. I should also mention I have heard it occassionally on a big bump.
Ask the shop if they used aftermarket rebuild parts. For second gear they must have since the factory requires you to replace the output shaft which is 1200.-1500. I have noticed the Brass synchro rings are not as good as the factory style rings at high rpm shifting. All aftermarket kits are brass.
Verify the shop has installed brass synchro-rings, if so then try an 80w gearlube for manual trannys. I havent tried that one yet. If that doesnt do it then remove the gear lube and deal with it.
I am curious to hear what the shop tells you
Terry
Don't know if it's the same problem, but I had clicking under starting too. Check the crossmember, it's the black brace that's under the engine, you use it to jack up the front of the car, it runs parallel to the car pretty much in the middle. There are 2 bolts right behind the front bumper that hold this crossmember to the chassis, mine were loose. This crossmember is part of the engine and transmission mount, so when you start to move the engine/tranny move and cause the crossmember to move, making this noise. I tightened the bolts up and it went away. Just make sure to put upward pressure on the crossmember when you tighten the bolts, as in using a jack to lift the car. That way the crossmember is flush to the chassis when you start to tighten it. The bolts might be hard to tighten too. It's common after a tranny rebuild because you need to remove that crossmember in order to pull the tranny.
Thanks guys! I appreciate all your tips! I will see what I can do and if I have to take it to the shop I will let you guys know.
  • Wanted 2g 1995 Eclipse GS-T Driver door cap wanted
    I'm looking for a 1995 GS-T driver side door cap or even a complete door with the proper door cap.
    • loco4G63
  • Wanted 1g MB668570 front ABS Ring for 1992 D27A
    I would really need front ABS rotors for my 1992 D27A eclipse with AWD. Would really appreciate...
    • Gurkigg
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
