Transmission rebuild help
ohTONYoh
173
6
Jul 29, 2012
yorktown, Virginia
Just took my trans out and split the bellhousing to put the new speed sensor ring gear on the differential. Everything is where its supposed to be, But The two halfs of the transmission on going together easy. Anyone know what i would need to do? ive aligned the bolts, aligners etc.
But there is this ring with cylinder things on it, on the speed sensor side(dont know what it is called)And one side the cylinder end is big, and the other is smaller. Im not sure which way goes where because it did fall out.
I guess i just need suggestions at this point.:confused:
