Trans / rear axle combo question
MarcVIII
103
Oct 23, 2004
Cleveland / Akron, Oh, Ohio
I have a GST Spyder 5spd I was looking to convert to 5spd AWD. Looking on ebay, I see the trans frequently is sold seperately of the rear axle.
I have an atx AWD Talon donor car. Can I use the rear axle in it, or would the ring gears inside not mesh with the gearing in the trans? Is there a "best" awd trans to go for?
Also reading about LSD / non-LSD axle shafts. Will an LSD or non-LSD rear end work?
Searched and didn't find an answer. Any help appreciated.
LSD and non LSD axles are the same. 3 bolt and 4 bolt are not.
The gearing is divided between autos and manuals.
So if you're putting an AWD 5 speed in the car you need an AWD 5 speed rear end.
Also, this is peanuts compared to the task of converting to AWD. Have you really read up on what is required?
