trans problem
90 Talon AWD
148
Aug 27, 2008
jonesville, North Carolina
okay so i am in the process of swappin motors i have the original motor out and i cannot seem to get the trans off of the motor i have removed all the bolts but the trans will not let go we have had it level and tried to pry it off but it wont go passed a certain ponit any help on this would be greatly appreciated
thanks
Is it an automatic or manual? Did you have any problems prior to taking the motor out? The TOB could be stuck to the pressure plate. If it's an auto did you unbolt the torque converter from the flexplate?
Are you sure you removed all of the bolts that hole the bell housing to the block? How many did you end up with?
Does it pull away from the block all the way around?
