jonnyb
- 0
- Aug 24, 2005
fox lake,
Illinois
last night i was drivein my car when i got to my buddys house it leak out all the gear lube.but i did not find any holes in the trany.it seemd to be comein out off the bellhousing.so i followed
the trail and found out where it happend at and there was some gear oil and cluth pices.there was no metal chunks or any thing. dose any body no wherer i could be leaking this gear lube
from.all gears in trans work and i can still drive it if it wasent for no gear lube in the trans.thanks
I sounds to me like its leaking out of the input shaft seal. If there are "clutch pieces" in there too you need to pull the tranny anyway to replace that, while its out, check the seal.
.ill give u a msd digital dsi 2 ignition.post back thanks guys for the help so it shouldent be critical
