Leitnin
- 246
- 7
- Mar 31, 2003
alright guys. Maybe you can bail me out of this one.
I rebuilt a toyota camry motor which i had some questions in another thread. Got the transmission bolted on, installed everything, and the engine wouldn't crank.
It was having an issue with the alarm, but then as my buddy was trying to start it, i noticed the crank pulley was moving a little.
Well, before I could get over to have him stop trying to crank it, the engine broke loose and turned over.
So, now the engine runs but putting the car in reverse or any drive gear it doesn't move.
heres a list of what i know.
1. the Torque converter had fluid in it such that when i put it back on the motor, it dripped a little, so i think it was primed okay.
2. Getting the trans on the motor was a huge pain, lining them up with no transmission jack, possibly not lined up correctly, except that onve it was lined up it went together pretty well.
3. when i put the car in reverse, the reverse lights do come on, (but i don't know if the lights are a separate mechanism from gear selection, i.e. neutral safety switch)
4. The cable is hooked up and moves freely when i change gears.
5. the wheels spin independently of the engine in all gears with the car on and off.
6. The dipstick reads the correct level, but i don't know if the fluid is being circulated everywhere, and if there is enough pressure to change gears.
i'd appreciate any ideas. worst case, the motor may come back up tomorrow to inspect the torque converter and reassemble.
really would rather not of course.
thanks guys!
thanks guys!
