2G Trans Cooler Question
95GreenGSX
365
Sep 14, 2006
Chicago, Illinois
So, I recently got a trans cooler from IPT. It says the flow has to go a certain direction, is this true? Or can I just put in the trans cooler any way? Also, how do I know what direction the trans fluid flow is coming from? Thanks
Here is the kit. Its 19,000 GVW
The fluid can run either way through the cooler. I've got the same cooler, I looked in my instuctions and it said it didn't matter which direction the flow went. One thing I would make sure you do is run it in series with your stock cooler ipt and your instuctions recommend this. To tell which way the coolant is flowing, pull both lines off your stock cooler, start the car, put it in netural( with the parking brake on) and look at the hoses, the hose with the fluid coming out of it is the supply the other is the return.
You want to keep the cooler's inlet & outlet parallel to the ground... That way you won't be trapping air bubbles at the top of the cooler.
The fitting that is closest to the firewall on the tranny is the return line.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
