Trans carnage! Is it fixable?
shawnc16
Dec 15, 2009
Lapeer, Michigan
So we pull the trans out yesterday.. knowing the throwout bearing is shot and low and behold, this is what we find. Is the hub that goes around the input shaft replaceable?
If you have access to a tig, it might be worth a shot welding back on. The trans still has to be torn apart as the little oil seal behind there will take a dump because of the welding heat.
A bell housing would be the right way to fix that. Ya nevermind, you might as well just call it a day on that trans. Find a donor bellhousing. I have a couple, PM me. Shipping aint gonna be cheap though.
