tranny swap AWD...needed items?
KeithL322
42
Oct 6, 2005
Clarksville, Indiana
ok so Im putting a New(used, but supposedly good synchros) AWD tranny into my car, what all should i be replacing in the drivetrain that wears out over time(15 years or so)/items i will need to complete this, the clutch is still good from what i know from driving it, and im buying a fidanza lightened flywheel, but anything like, shift forks etc need to be repaced from wear?...and info will help a ton! thanks!
pivot fork and ball, throw out bearing. might want to replace the axle seals while you are down there.
Also check all your mounts and stuff, cant hurt to have a look around the entire engine. Also, while you are down there, replace the gear oil in your transfer case and rear diff if it has not been done in a while.
Check your lateral arms joints to make sure they are ok as well. You dont want those failing on you.
