Tranny spline #?
Distingishing between the different transmissions all has to do with the output shaft of the transmission to the input shaft of the transfer case.
Count the number of splines on the output shaft of the transmission. It should either be 22 or 23 splines. To the best of my knowledge, 90's are the only transmissions that came with 22 spline output shafts. To do this, simply remove the transfer case and count the splines on the output shaft of the trans...
So, to awnser your question, no, a 23 spline transmission is not interchangable with a 22 spline transmission...
If you get a 23 spline transmission, a 23 spline transfer case, and a 91-94 shifter assembly (cables and all), you can upgrade from the 22 spline trans setup...
Scott
