tranny sound
DSM X
Nov 29, 2009
Des Moines, Iowa
my clutch fried so i replaced it and it was making kind of a rattling sound before i changed it, and i believe it was my throwout bearing rattling against the pressure plate because of the wear around the bearing and the wear on the plate. after replacement with new oem clutch kit it continues to make the sound. what could be causing this??
The Throwout bearing is the key part of the clutch assembly that initializes the disengagement of the Pressure plate and the clutch. Just think, every time you press in on the clutch, this bearing has to forcefully press against the fingers of the pressure plate. It breaks down over years and extended use and will eventually get to the point that it was at when you replaced the clutch.
This is normal. Just change it with the proper OEM throw out bearing and you'll be fine.
Everything you said was reffering to before you changed the clutch. Is it still making noise?
i know how it works ;)
i replaced with new oe clutch assembly came with clutch pressure plate and throwout bearing, and yes its still making the noise sorry i meant to put that in my post, and i just cant figure out why its making the sound still, iv looked at assembly diagrams and im positive everything is correct, im stumped
is there some sort of fastener that holds the bearing to the fork?
Welp, I was more apt to help considering that all available information was supplied in the initial post. Now? Eh.
