tranny is weird .....read mor inside
girlpower92
147
Mar 24, 2005
perry, Ohio
ok it feels like the clutch isnt pushed in all the way or something. cuzz it wont go in to gear some times only sometimes in less i hold it in place then it slips in in 1 second. or grinds in its not bad but its kinda pissing me off. it will grind in to revers sometimes and then its fine it not loud or anything it just feels like i need to push the clutch in more but its all the way to the floor. what could this be ?
do i need to bleed the clutch?
new trany fluid ?
or clutch fluid ?
im waiting for my act2600 to get here 2marrow but i want this fixed b4 i install it
does it grind going into gears? does it do it more when the car is cold? drain your tranny fluid into something clean, look for any brass or metal shavings or it may come out rather dirty. you could have syncro's going bad. try using penzoil syncromesh in ur tranny. if you find there are metal shavings well, give shepardracing a call for a rebuild. thats where my tranny is right now and he's in ur state. good luck with the new clutch as well.
