Tranny Help Needed ASAP!
greddy_1700
1,036
91
Aug 27, 2006
Regina, SK, Canada
Hey, So I am in a bit of a panic here. I am involved in quite the little weekend project and as always something has to go wrong. I was replacing the clutch and transmission on my 91 AWD only to find out that the Center Shaft on the transmission I was putting in is lose. Now I opened up the Rear Cover to see if there was a snap ring or something that had come lose and I found a small steel ball in the case. Now as far as I can tell that ball goes in the little grove inside the spline on the Viscious Coupling correct? Is that how the Center shaft is held in place? If so how do I go about getting the Center shaft to fit back over the ball? Do I just use a hammer or would something like a C-Clamp be better suited. Please help as I was hoping to get this job over and done with this weekend.
On a side note I am replacing my Ball Joints, Tie Rods, CV shaft, Wheel bearings, Seals, Transmission, Transfer Case, Clutch and Flywheel. I shouldnt complain if this is the worst I have to deal with...
Thanks in Advance,
Garret
Nevermind... Some frustration, anger, and the use of my DSM Specialty tool got the job done. When in doubt, pound the **** out of it.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
