tranny/clutch or flywheel issues
90tsitalonfwd
72
Apr 16, 2008
Tulsa, Oklahoma
ok so this been an unsolved problem for quite a while now. whatever i do i cant seem to get enough pressure in the clutch pedal to get the car to go into gear it just grinds. i have a new clutch, pressure plate, throwout bearing, slave and master cylinder and ive bled it like 100 times. Also i have an aluminum fidanza flywheel that seems to be rubbing on the inside of the transmission case???!! what could cause that? the only thing i havent done is replaced the aftermarket flywheel with a stock one and see if thats the problem.... any ideas or suggestions???
Did you have your flywheel machined? You absolutly have to have that baby machined to specs or you will have issues with your clutch pedal as far as the slave you can install a longer rod but if you have no more throw in it , dude you just dont have anymore, im telling you from experience i did a tranny and clutch job on my 98 gst and skipped the fly, and guess what i had to take it all out and do it all over again
