MichaelSuch
- 932
- 58
- Jun 30, 2008
Pinckneyville,
Illinois
Hey guys, I'm having the tranny being rebuilt by a local transmission shop. I had the motor out with the tranny and the transmission was grinding a little in second gear so I figured it would be the perfect time to fix it. I take it to the shop, they opened it up, found out that I needed a 2nd gear Hub/Sleeve, 2nd gear, 2nd gear synchros, and a tapered roller bearing. I called up JNZ Tuning and it was about the same price for the stock parts as it was for the dual cone synchro set. I figured it would be better to go with the dual cone set since in another 100k miles I'll end up with the same problem. I gave them my VIN number, build date of the car, and how many teeth were on the 2nd gear and had the parts shipped to my house.
Took it to the shop about a week ago, he said everything looked fine. Today he called me and said I have the wrong parts. He said that the original was a 1 piece synchronizer design and I gave him a 3 piece. I said yep, its a newer design and explained the purpose of the dual cone synchronizer. He said it still wouldn't work. For it to work it would require a "low" gear even then it may not according to him. I'm fairly certain JNZ sent me the right parts, I think the guy at the shop just doesn't know what he's doing. When I asked him to get some numbers off the transmission case while we were on the phone he flipped it over and goes just broke that part which was a plastic baffle, which I have never heard of. Now I have to buy that part as well. He has worked on quite a few Manual transmissions and a lot of engine builders here recommend him so I figured installing the 2nd gear synchro set wouldn't be a problem. I knew I should've attempted the rebuild myself but I felt more comfortable taking to someone that would know what they're getting into. He doesn't seem to really try and install the parts or tell me exactly what's wrong with the parts I gave him. I would like to take it back and try it myself or send it to someone that rebuilds DSM transmissions but he's already going to charge me around $100 for labor. What should I do?
