greengoblin
Supporting Vendor
- 1,571
- 398
- Mar 10, 2006
McKinney,
Texas
The best low good handling spring setup is (IMO) Koni yellow with H&R springs. Like I said before. Sportlines look good and NOTHING else.
Kevin
Kevin
The higher the number, the stiffer the spring. If you're happy with what you have now, then I'd stick to something around that spring rate. Once you start going up, the ride will definitely get rougher.
I agree with Grant. You're looking more for a set of springs that gives you a nice ride and a really low look over something that is a performance piece - which is perfectly fine. Stiff springs aren't for everyone.
Kevin
What h&r springs? There are like 3 different types
Okay well I currently have the tokico springs and I called up tokico and they said the rates were 285 for the front and 160 for the rear. I am extremely happy with them. I called eibach yesterday and they said the sportlines are 220-320 in the front and 89-194 in the back. Which have better rates? Does that mean the sportliness are stiffer? I don't care how harsh the ride is as long as its not bouncy.
The Tokico fronts are 285 and the Sportlines are 220-320. If you really push the Sportlines, they will be stiffer.
The Tokico rears are 160 and the Sportilnes are 89-194. If you really push the Sportlines, they will be stiffer.
since mine is a daily driver i am right now running 0* in the front and 1.6* in the rear. I am also stock height as this is my dd and i like clearing speed bumps. :] Best way to tell is with a heat gun and a couple trips to the track.
This is excellent! This means when I am daily driving the ride will be more comfortable but when I want to have some fun it will be even stiffer than the tokicos. Good info snowboarder!
0* camber on the front!? I guess you hate any though of wheel spin.
As bad as these cars understeer, I think you'd want some camber in the front.
