TPS Trouble
Spyder4g64
356
Mar 9, 2005
Wallingford, Connecticut
My car is throwing a CEL for TPS circuit malfunction. DSMLink shows a RAWTP of 1 at closed throttle, and 255 at WOT.
Isnt the TPS Volts supposed to be at ~.63V at closed? Mine is showing 0 volts closed, and 5.00V WOT.
Is there a way to fix this?
It is supposed to be .63v with the ignition on. At wot i get around 4.80v which is 96% throttle I haven't had time to adjust it to 100. Try adjusting it both manually and through dsmlink offset, or swap it with another one.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
