Drewpy Dawg
- 271
- 304
- May 18, 2008
Sachse,
Texas
I know some people here have done the Toyota electric power steering swap. It’s not something I’m planning to do until my car is running and driving, but I’m thinking ahead about the possibilities.
None of the installs on various cars that I have seen online use the vehicle speed input to the steering ECU, and therefore the steering is in full assist any time the ECU is powered on. From what I have found searching it appears the speed signal to the steering ECU is just a PWM signal, like our OE vehicle speed sensors produce. It seems to me that it would be very easy to add a VSS signal and get the speed sensitive steering that the factory built into the ECU. You could even manipulate the PWM signal to dial in exactly how much assist you want at low or high speeds. Full assist at parking speed but tapers off very quickly once rolling leaving you with the full feel and feedback of a manual setup. Tapping into our stock VSS would be trivial.
Has anyone done this on their EPS install? Anyone know any reasons why it wouldn’t work or why it’s “not that simple”?
