Torque
Status
Not open for further replies.
1. a bigger turbo
2. more boost than stock
3. street cams
4. lean out your fuel from stock
5. advance your timing
6. and research :thumb:
but almost all of these things also give you more horsepower, too. so if you JUST WANT TORQE, swap in a powerstroke :notgood: .
dsm-onster said:
But almost all of these things also give you more horsepower, too. so if you JUST WANT TORQUE, swap in a powerstroke.
Anything that increases the torque at a rpm also increases the HP at that same RPM since HP = (torque * RPM)/5252.
Steve
Superbeast406 said:
start with a stroker kit
You have GOT to be freaking joking right WTF START with a stroker kit? :rolleyes:
Anyway, most mods you do will increase your torque and power, the quicker the spool up the more torque you will get down low too.
the the simple bolt-on mods. 3inch full exhaust, intake, boost controler, bov and upper intercooler pipe. that will bring your turque up by like 40-50lb
ur fwd...too much torque is just gonna make you spin so watch that...cuz that could turn into ur worst enemy...but yea the question has pretty much been answered already...good luck tho
i have seen some many different spelling of the word "torque" in this thread......
Status
