torque specs?
9920gGST
Aug 27, 2006
Hayden, Alabama
where might I find the torque specs for a fidanza flywheel and a spec stage 3 clutch?
For fidanza flywheel recommended torque is 90-110,but i always used 115 ;) make sure you will put a Red Thread Locker,because the bolts might come loose and will f**k up your tranny and clutch. On a clutch pressure plate is 20 Lbs/ft of torque ;) use the thread locker on Pressure plate too!! ;)
